Хотел бы добавить ещё один вопрос: В 66 и 888 классификация по цветам пружин одинаковая? Если да, тогда встречный вопрос: У меня 66 RC2X, в ней стоят синие (голубые) пружины. Какой они жёсткости?
Нашел такие сведения на сколько они верны ? _____________________________________________________ Fox 40 Coil, Titanium Spring:
Fox 40 Steel Spring, Black, X-Soft = 30 (40кг-55кг) 039-05-070 Fox 40 Steel Spring, Purple, Soft = 35 (55кг-70 кг) 039-05-071 Fox 40 Steel Spring, Blue, Medium = 40lb (70кг-80кг) 039-05-062 Fox 40 Steel Spring, Green, Firm = 45Lb (80кг-95 кг) 039-05-073 Fox 40 Steel Spring, Yellow, X-Firm = 50lb. (95кг-110кг) 039-05-074 Fox 40 Steel Spring Orange___210 – ≥240 (95 кг-110кг) 039-05-075 Fox 40 Steel Spring Red_____210 – ≥240 (95 кг-110кг) 039-05-076 ______________________________________________________________________________ Dorados / xvert carbons Blue soft = 60 lb red medium = 80 lb yellow firm = 100 lb
____________________________________________________________________________ Monster T's Spring length is 320mm Green = stock springs in 99-02 monsters = progressively wound springs, start at 2.5 kg/cm and ramp up to 3.5 kg/cm (14lbs/inch to 19.6lbs/inch)
Yellow = Soft = 2.5 kg/cm (14 lbs/inch) White = Medium = 3 kg/cm (16.8 lbs/inch) Blue = Firm = 3.5 kg/cm (19.6 lbs/inch) Red = heavy = 4 kg/cm (22.4 lbs/inch) ________________________________________
Shiver Spring length is 334mm Soft = 2.7 kg/cm (15 lbs/inch) Medium = 3.2 kg/cm (18 lbs/inch) Firm = 3.7 kg/cm (21 lbs/inch) _________________________________________
Boxxer Spring length is 390mm White = Soft = 10lbs/inch Silver = Medium = 15lbs/inch Yellow = Firm = 20lbs/inch Red = Extra firm = 25lbs/inch (??i think??) __________________________________________
