Решил добавить в свою конюшню вот такой пепелац для трейла и гор самое оно)))), из ощущений катит лучше, чем скотт спарк 60, ну и обработка всяких там неровностей фоксом просто класс.
Сейчас вдуто в вилку 85пси /180 пси в аморт на вес 82 кг как раз нормально
Спецификация: FRAME FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
REAR SHOCK Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
FORK Fox Float 130 RL, 130mm, rebound/compression adj, lock out, alloy steerer
HEADSET 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
HANDLEBARS Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
TAPE / GRIPS Specialized MTB, dual density
FRONT BRAKE Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
REAR BRAKE Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL 185mm rotor
BRAKE LEVERS Avid Juicy 5
FRONT DERAILLEUR Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR SRAM X-9, 9-speed, long cage
SHIFT LEVERS SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11/34t
CHAIN SRAM PC-971 w /Power Link
CRANKSET Truvativ Stylo, 2pc crank/BB
CHAINRINGS 22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET Truvativ GXP, sealed outboard cartridge bearing
PEDALS Wellgo MG-1
RIMS DT custom for Specialized X430, 24mm w/eyelets, 32h
FRONT HUB Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB Shimano M-525 disc, 32h, alloy QR
SPOKES DT Swiss 1.8mm stainless, black, alloy nipples
FRONT TIRE Scwable nobby nic 26/2,25 EVO
REAR TIRE Scwable nobby nic 26/2,25 EVO
TUBES Specialized Ultralight 26x2.12", presta
SADDLE Specialized BG Rival, hollow Cro-Mo rails
SEAT POST 2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
NOTES Protective clear coat, derailleur hanger, reflectors, owners manual
| Вложения: |
IMG_1904.jpg [ 80.21 КБ | Просмотров: 1030 ]
